Keenetic Hero 4G+ (KN-2311) router has the Mobile Network indicator on the housing.
Blinking blue — Connecting to a mobile broadband network.
Off — The built-in 4G modem is disabled.
RSSI (Received Signal Strength Indicator) is an indicator of the strength of the signal received by the modem. The value is measured in dBm
. The minimum value acceptable for network operation is -85 dBm
The higher the RSSI number, or the less negative it is, the stronger the signal strength (e.g. a value of -45
is greater than -80
). The RSSI indicates the power level of the signal received by the modem, not the power level of the base station signal.
The green light is on when RSSI >= -75 dBm
, and the blue light is on when RSSI < -75 dBm
-65
Good: RSSI between
-65
and-75
OK performance: RSSI
-75
to-85
Poor: RSSI falling below
-85
