Changing the GSM/3G/LTE mode on Huawei USB modems
KeeneticOS can lock 2G (GSM), 3G (UMTS) or 4G (LTE) network mode for Huawei USB modems.
The setting is accessible through the command-line interface (CLI) of the router with the command:
interface <interface_name> usb acq gsm/umts/lte
This command is applicable for Huawei modems operating in RAS/NDIS mode.
To work in the 2G (GSM) network only, you need to execute commands:
(config)>interface UsbLte0
Core::Configurator: Done. (config-if)>usb acq gsm
Network::Interface::Usb: "UsbLte0": ACQ saved. (config-if)>exit
Core::Configurator: Done. (config)>system configuration save
To apply the 3G (UMTS) network:
Core::Configurator: Done. (config-if)>usb acq umts
To apply the 4G (LTE) network:
Core::Configurator: Done. (config-if)>usb acq lte
To delete a setting, follow the commands (example for a 4G network):
Core::Configurator: Done. (config-if)>no usb acq
Network::Interface::Usb: "UsbLte0": ACQ cleared. (config-if)>exit
Full interface names
You can see the interface names of your Keenetic by entering the command
show interface
Then pressing Space and Tab.
Pay attention to the interface names. It is necessary to consider a letter case when using interface names in commands. For example, the interface names UsbModem0
and UsbLte0
contain both capital and lowercase letters.
