Method 1
    For models that do not have a hardware mode selector on their cases, enable the optional mode in the web interface. On the 'General System Settings' page, click the 'Change operating mode' button and set the Extender Mode.
  5. Open a web browser, go to my.keenetic.net, log in to the Main Router's web interface. Open the 'Mesh Wi-Fi system' page and click 'Acquire' to add the Extender to your Wi-Fi System.
    The Keenetic Wi-Fi System supports both wireless and wired connections between the Main Router and Extenders for maximum network bandwidth and stability. For information on the components and performance of your Wi-Fi System, see the 'Wi-Fi System' section of your Keenetic web interface.
Method 2
You can do the same by using the Wi-Fi network management button with the WPS Quick Setup mechanism.
    For models that do not have a hardware mode selector on their cases, you can change the mode in the web interface. On the 'General System Settings' page, click the 'Change operating mode' button and set the Extender Mode.
    If you use a dual-band Keenetic model Giga (KN-1010) as an Extender, push the Wi-Fi button twice to connect to a 5 GHz wireless network. In the same way, push the button twice on the Main Router. If you push the Wi-Fi Control button once, you'll be connected to a 2.4 GHz Wi-Fi network.
  5. Open a web browser, go to my.keenetic.net, log in to the Main Router's web interface. Select the Wi-Fi System section and click 'Acquire' to add the Extender to your Wi-Fi System.
    Keenetic Wi-Fi System supports both wireless and wired connections between the Main Router and Extender for maximum network bandwidth and stability. For information on the components and performance of your Wi-Fi System, see the 'Wi-Fi System' section of your Keenetic web interface.
    If there is no 'Wi-Fi System' menu section in the settings of the Main Router, in this case, a special component 'Wi-Fi System controller' must be installed. You can do this on the 'General System Settings' page in the 'KeeneticOS Update and Component Options' section by clicking on Component options.
