Keenetic Runner 4G (KN-2212) router has the Mobile Network
indicator on the housing.
Blinking slowly blue — Searching for a mobile broadband network.
Blinking rapid blue — Connecting to a mobile broadband network.
Off — The built-in 4G modem is disabled.
RSSI (Received Signal Strength Indicator) is an indicator of the strength of the signal received by the modem. The value is measured in dBm. The minimum value acceptable for network operation is -85 dBm.
The higher the RSSI number, or the less negative it is, the stronger the signal strength (e.g. a value of -45 is greater than -80). The RSSI indicates the power level of the signal received by the modem, not the power level of the base station signal.
The green light is on when RSSI >= -75 dBm, and the blue light is on when RSSI < -75 dBm.
-65Good: RSSI between
-65and-75OK performance: RSSI
-75to-85Poor: RSSI falling below
-85
