KeeneticOS 3.7
Highlights at a glance
Release 3.7 is jam-packed with new features, fixes and improvements. These highlights are only the beginning:
See which applications run on your network. The new Traffic Classification Engine detects thousands of applications in real-time and displays them for you in the Traffic monitor and Application traffic analyzer.
Manage all your networks in one convenient Web Portal. The new Keenetic RMM system (now in beta) is a cloud-based multi-site remote monitoring and management solution purpose-built for Small/Medium-sized businesses to help keep critical networks and infrastructure online 24/7. Visit rmm.keenetic.com to learn more.
Enjoy multiple KeenDNS improvements, including automatic operating mode selection, the ability to password-protect remote access to the web applications, easy remote access configuration to attached 4G/3G USB modem dongles, and support for IP/FQDN web application targets.
Customize the Web interface title and header for ease of navigation between multiple Keenetic devices.
Set up IP-encapsulated tunnels (IPIP, GRE, EoIP) easily with the new configuration screen.
Visualize interference from neighboring networks in the 5 GHz band with Wi‑Fi Spectrum Analyzer.
Build a customized KeeneticOS image with your services and scripts using the Keenetic Software Development Kit (SDK) available on GitHub.
Learn more about the latest developments at the new device-tailored multilingual documentation portal.
As always, if you have any feedback (or want to say hi ), drop us a line in the forum. To learn more about Keenetic, visit the Help Center.
KeeneticOS 3.7.4
31/03/2022
Improved
Updated to the latest OpenSSL library version 1.1.1n, which fixes the CVE-2022-0778 vulnerability. [SYS-523]
Fixed
Fixed multiple remote peer support for OpenVPN connections. [NDM-2115]
Fixed the display of the Ports and VLANs settings on mobile devices. [NWI-924]
KeeneticOS 3.7.3
24/02/2022
Improved
We plan to add a user-defined setting for Wi‑Fi System Extenders to stop broadcasting Wi‑Fi networks if the backhaul connection to the Wi‑Fi System Controller is lost. Meanwhile, the new behaviour introduced in KeeneticOS 3.7 Beta 1 is temporarily disabled to prevent issues with specific Wi-Fi System configurations in the field. [NDM-2068]
Fixed
The Speed limit setting for a host no longer causes the system to reboot under certain conditions. [SYS-375]
The Band Steering algorithm has improved signal level measuring to prevent early swapping of wireless clients between 2.4 and 5 GHz bands. [SYS-379]
The KeeneticOS now operates correctly with a
startup-config
file size of more than 64 Kbytes. [NDM-2090]The Wireless ISP connection can now link correctly to a third-party Wi-Fi network with an active
backhaul
support bit. [SYS-479]The Wireless ISP tile for 5 GHz connection on the Dashboard menu now links to the proper path, Wireless ISP > WISP 5GHz. [NWI-872]
KeeneticOS 3.7.2
27/01/2022
New
A new configuration option for improved compatibility with legacy Wi-Fi clients: Control the TKIP countermeasures
hold-down
timer. If the Wi‑Fi Access Point with WPA-PSK + WPA2-PSK protection mode detects twoMIC errors in RX
failures within 60 seconds, it blocks all the wireless TKIP clients on that interface for the hold-down timer. Use this command to disable or tune this behaviour. [SYS-434]interface {name} encryption tkip hold-down {hold-down}
— set thehold-down
timer in seconds (from 0 to 60). The default value is 60 sec.
Improved
Fixed
Fixed a sporadically occurring situation when data transmitted from the wireless interface of Mesh Wi‑Fi System Controller to an Extender, for instance, DCHP protocol, is blocked after reconfiguring the network segment. [SYS-436]
The LED power shutdown control now operates correctly with Keenetic devices having a single-LED indicator. [SYS-422]
Fixed an error in accessing the device's Web Interface after a few days of operation, causing the following messages in the System log. [NDM-2046]
ndm: Http::Nginx: there are errors in config, reconfigure.
ndm: Http::Manager: unable to update configuration, retry.
The IPv6 section of the System dashboard menu now displays only the default IPv6 gateway for the corresponding interface. [NWI-823]
Fixed the Fast Transition (802.11r) roaming selector behaviour in the Roaming for wireless devices section. [NWI-816]
KeeneticOS 3.7.1
14/12/2021
New
Implemented Wi‑Fi Spectrum Analyzer. The dedicated Spectrum Analyzer radio continuously scans all 5 GHz Wi‑Fi channels and visualizes the level of interference from neighbouring networks to help channel selection and planning. [SYS-297, SYS-393, NDM-1908, NDM-1858, NWI-590, NWI-708]
Added a user-defined caption to the Web Interface header and a browser tab providing improved navigation between multiple Keenetic devices. [NDM-1764, NWI-424, NWI-428, NWI-429, NWI-555, NWI-556, NWI-558]
The Traffic classification engine (NTCE) now offers prioritization for a comprehensive set of application categories via the service classes. The new CLI commands are listed below. [NDM-1683]
— assign certain priority for certain categoriesntce qos enable
— enable QoS processing for thentce
(network traffic classification engine)
The Traffic classification engine and IntelliQoS system component is replaced by the Traffic classification engine system component of the KeeneticOS. It implements the detection and classification of applications and protocols.
Categories and Applications diagrams appeared in the Host traffic monitor menu of the Web Interface. Also, a new item, Application Traffic Analyzer, appeared in the Status section. Currently, new sections become visible after the component is installed and the service is enabled via the
service ntce
CLI command. The component operates autonomously and does not depend on any external services. [NDM-1476, NDW-2109]
The KeeneticOS build system is now available on GitHub. You can use the Keenetic Software Development Kit (SDK) to build a customized Keenetic firmware image with your own services and scripts. [NDM-1398]
Improved
Enhanced Wi‑Fi Network protection: WPA2 Enterprise exchange with a RADIUS server now has Network name (SSID) in the
Called-Station-Id
message —'50-FF-20-AA-BB-CC:Keenetic-5555'
. [SYS-9]
Implemented
/storage
partition formatting on factory reset, providing secure clearance of the private user's information or installed OPKG image. [NDM-1943]
Removed an error message that occurred if an IP address was configured instead of a URL (Uniform Resource Locator) for a DoH (DNS over HTTP) server:
. [NDM-1938]Enabled centralized Wi‑Fi
country code
configuration from Wi‑Fi system Controller, and blocked this setting on Extenders. [NDM-1921, NWI-733]Improved operability of the Wi‑Fi connection in a noisy environment. [SYS-398]
Redesigned the display of active channels, and the colour legend of Wi‑Fi Channel utilization in the Wi‑Fi spectrum analyzer. [NWI-734]
Closing of Traffic monitor additional tabs is now allowed in mobile browsers. [NWI-666]
Added links to the Internet connections settings from the dashboard Internet tile, providing a fast way to edit connection(s). [NWI-682]
The PSK (PreShared Key) length is extended to 96 characters for IPsec and L2TP/IPSec VPN servers. [NDM-1780]
Implemented brute-force protection for remote access to the device via the KeenDNS domain name in the Cloud access mode. [NDM-1804]
The KeeneticOS update process is optimized to run in the background to minimize system downtime. Keenetic has dual flash memory with active and backup KeeneticOS images to ensure fail-free automatic upgrades. When a new version of the operating system is released, the device will download, store and check the integrity of the software image in the backup partition first, without interrupting the main operation. Then the Keenetic device reboots, running the updated KeeneticOS version. Internet access will be briefly interrupted only during the device reboot. [NDM-1861]
The hostname value is added to the Syslog message's payload when sending records to a server to simplify log analysis from multiple Keenetic devices. [NDM-1872]
Updated Wi‑Fi wireless driver to new version
7.5.0.0
. [SYS-373]Improved security: After changing user credentials, KeeneticOS cleans up active management sessions via the Web Interface and the Keenetic mobile application. [NDM-1860]
When a wired Ethernet backhaul link is used to attach a Wi‑Fi System Extender to a Wi‑Fi System Controller, setting up custom Wi‑Fi channels on the Extender is now possible. Setting non-overlapping Wi‑Fi channels on different Wi‑Fi System nodes will maximize wireless clients' performance. If a wired Ethernet backhaul link disconnects, the Extender will automatically switch to a Mesh wireless backhaul link to resume operation. In this case, depending on the Mesh wireless backhaul interface, the corresponding Wi‑Fi channel on the Extender will follow the backhaul link. Once a wired Ethernet backhaul link is restored, the Extender will automatically use wired backhaul and preset Wi‑Fi channels. [NDM-1801]
The Active connections information sheet moves to a separate tab on the Diagnostics page, providing a list of sessions established via your Keenetic device. [NWI-414]
A Wi‑Fi System Extender will stop broadcasting Wi‑Fi networks if the backhaul connection to the Wi‑Fi System Controller is lost, to help Wi‑Fi clients re-connect to a working Wi‑Fi System node faster. [NDM-1707]
Added a Compressed RAM disk for system swap (zRAM) toggle to the System settings page. [NWI-405]
Improved DNAT session recognition by the Traffic classification engine system component. [SYS-319]
Implemented stopping of the Traffic classification engine service to free system memory before a KeeneticOS update. [NDM-1756]
The system Debug control relocates to a dedicated tab in the Diagnostics section. [NWI-401]
Improved the application identification and traffic accounting accuracy of the Traffic classification engine system component. [SYS-309]
As of now, the Keenetic Traffic classification engine recognizes 1400+ of the most popular Internet applications. In addition, Uncategorized traffic is now visible in the Applications and Categories views of the Traffic Monitor. [NDM-1210]
Implemented automatic merging of the least important data to the Uncategorized group to optimize memory usage by the Traffic classification engine and enable protection against memory overflow. [NDM-1681]
Seamless navigation from Wi‑Fi System Controller to Extenders is available now. Click the Extender name on the Mesh Wi‑Fi System page to jump to the Web Interface of the Extender. Each Extender has a unique navigation web address under the
*.keenetic.io
domain. Security tokens and automatically installed SSL certificates ensure safe and secure operation. [NDM-1287, NWI-323]Added the Optimization mode selector to the IPsec VPN server application settings. It changes the set of supported encryption algorithms, as follows. [NDM-1259, NWI-327]
Default — enables all encryption algorithms except
DES
and3DES
;Legacy — enables both
DES
and3DES
for compatibility with legacy clients;Performance — enables modern encryption algorithm
CHACHA20-POLY1305
only, for faster and secure data exchange with supported peers.
It is now possible to edit Speed limit settings for devices with internet access blocked according to schedule on the Device lists page. [NDW-2427]
Added new IntelliQoS priority configuration page in the Web Interface. It ensures inbound, and outbound, bandwidth for prioritized applications and tasks via pre-defined, drag-and-drop category group presets. [NDW-2413]
Updated the Web Interface of the KeeneticOS to address the CVE-2021-23017 vulnerability.
Added Password protected access to web applications running on your network via the KeenDNS service. [NDW-2202]
Redesigned the Access to web applications running on your network section of the Domain name > KeenDNS page for better visibility and easy management. [NDW-2203]
Added the Auto option for the KeenDNS operating in IPv4 mode, providing automatic detection of obtained IP address type and flexible operation if this IP changes from time to time or you have a secondary/backup Internet access connection. [NDW-2243]
ICMP - Host unreachable
replaces theDROP
action for the internal firewall rule of KeeneticOS when the user's device is accessing a blocked DNS over HTTPS (DoH) / DNS over TLS (DoT) DNS server. This change helps to speed up fallback to allowed DoT/DoH DNS servers on the Keenetic device. [NDM-1470]It is now possible to use
and^
characters in the Username field of a DDNS profile. [NDM-1255]
The KeenDNS settings now allow specifying an IP address and FQDN as the HTTP proxy destination address in the Access to web applications running on your network section of the Domain name page. [NDW-2201]
Removed Wi‑Fi extenders from the list of devices that can be assigned a DNS filtering policy profile on the Internet safety page. [NDW-2108]
The firmware image build with the Keenetic SDK is now compatible with the Keenetic Recovery Utility for Windows OS. You can use this utility to upload a firmware image to your Keenetic device. [NDM-1530]
Implemented a new smart queue management algorithm — NDM Fast Queue (NFQ). NFQ is CAKE-based, and optimized for speeds above 24 Mbit/s. When you limit the Internet connection speed for a host or network segment at a rate above 24 Mbit/s, the NFQ algorithm performs shaping. For rates below 24 Mbit/s, the CAKE algorithm does the job. [NDM-1247]
DHCP server options 121 and 249 now allow configuration of routes with destination
0.0.0.0/0
. [NDM-1222]The CLI command for adjusting the TTL value of incoming IP packets has a new syntax: [NDM-1419]
— old syntax, obsolete now;interface ip adjust-ttl recv {recv}
— new syntax.
Fixed
Corrected seamless Wi-Fi roaming operation: The forwarding of the LLC frames of the Inter-Access Point Protocol daemon now operates accurately via a backhaul link of the Wi-Fi system. [SYS-427]
Fixed the inability to set up a static DNS server address with the custom port setting in the Web Interface, for example —
1.1.1.1:5353
. [NWI-766]Fixed the forced disconnect of live Wi‑Fi clients when removing them from the Whitelist of the Wireless ACL. [SYS-400]
Fixed the false advertisement of 802.11k capabilities in Wi‑Fi network beacons. [SYS-414]
Wi‑Fi system dynamic Fast Transition (802.11r) key exchange now operates appropriately when an Extender has the IP address changed over time via DHCP. [SYS-354]
Fixed the occasional false "4 GBytes" bursts of apparent traffic in the Traffic monitor. [SYS-396]
The Static IP address assigned to a registered device now works more reliably. [NDM-1893]
Disabled validation of the DoT (DNS over TLS) / DoH (DNS over HTTPS) certificates until the system time of the KeeneticOS is synchronized. [NDM-1910]
Fixed the incorrect connection type in the More information section for Registered devices currently offline. [NDW-664]
The operation of the Wireguard VPN causes
no buffer space available
error message in the System log. [NDM-1913]
Restored the operation of simultaneous Wi‑Fi roaming zone and Wi‑Fi band restrictions applied to the device. The settings now propagate correctly to newly acquired Mesh Wi‑Fi System extenders as well. [NDM-1869, NDM-1875]
Fixed Network Time Protocol (NTP) server response validation under certain conditions. [NDM-1880]
Increased the server address length to 256 characters for PPTP and L2TP connections. [NDM-1907]
The Traffic monitor statistics now display correct information after changing settings on the WAN interface. [SYS-389]
Disabled requests from the Extenders to the Mesh Wi‑Fi Controller DNS proxy in additional segments. The Extenders now use Home segment only for system DNS requests. [NDM-976]
The availability checking for the SkyDNS® service now operates correctly when no additional DNS servers are configured. [NDM-1761]
The IKEv2 VPN tunnel now operates properly as a primary Internet connection along with the logic of automatic IKEv2 tunnel source selection. [NDM-1855]
The Wi‑Fi roaming setting synchronization between the Wi‑Fi System Controller and Extenders now operates properly. [NDM-1668]
Eliminated the root cause for the
unable to reset loop detector
errors in Extender logs. [NDM-1658]Fixed the reason for the
Rtx::Iapp: unsupported interface
errors in Extender logs. [NDM-1753]
Fixed the reset to default MAC address on a wired connection with IPTV port option enabled. [NDM-1771]
Fixed Wi‑Fi operation with 802.11v WNM (Wireless Network Management) roaming enabled. [SYS-325]
Fixed the Wi‑Fi Extender IP address refresh for networks with multiple segments. [NDM-1752]
Removed the password prompt flick when navigating from the Mesh Wi‑Fi System page of a Controller to connected Extenders. [NDM-1724]
Fixed system configuration synchronization between the Mesh Wi‑Fi System Controller and Extenders. [NDM-1668]
The system restart in the Extender mode under certain conditions. [NDM-514]
Fixed memory consumption by the Traffic classification engine component. [NDM-1425]
The operation of DoT (DNS over TLS)/DoH (DNS over HTTPS) services resulting in the error message
. [NDM-541]
Cleanup of obsolete TCP (Transmission Control Protocol) and UDP (User Datagram Protocol) sessions of the Traffic classification engine system component, which caused excessive memory consumption. [NDM-1496]
The detection of SIP (Session Initiation Protocol), RTP (Real-time Transport Protocol), and RTCP (RTP Control Protocol) protocols by the Traffic classification engine system component. [NDM-1576]
The application category classification on the Traffic monitor page of the Web Interface. [NDW-2231]
The sorting of the VPN connections in the Other connections section is now working correctly. [NDW-2169]
Devices in Extender mode used to crash under certain circumstances. [NDM-1546]
KeeneticOS 3.7 Beta 2
This is the initial shipping release for Keenetic Voyager Pro (KN-3510).
