KeeneticOS 3.7
KeeneticOS 3.7.4
29/03/2022
Improved
Updated to the latest OpenSSL library version 1.1.1n, which fixes the CVE-2022-0778 vulnerability. [SYS-523]
Fixed
Fixed multiple remote peer support for OpenVPN connections. [NDM-2115]
Fixed the display of the Ports and VLANs settings on mobile devices. [NWI-924]
KeeneticOS 3.7.3
18/02/2022
Improved
We plan to add a user-defined setting for Wi‑Fi System Extenders to stop broadcasting Wi‑Fi networks if the backhaul connection to the Wi‑Fi System Controller is lost. Meanwhile, the new behaviour introduced in KeeneticOS 3.7 Beta 1 is temporarily disabled to prevent issues with specific Wi-Fi System configurations in the field. [NDM-2068]
Fixed
The Speed limit setting for a host no longer causes the system to reboot under certain conditions. [SYS-375]
The Band Steering algorithm has improved signal level measuring to prevent early swapping of wireless clients between 2.4 and 5 GHz bands. [SYS-379]
The KeeneticOS now operates correctly with a
startup-config
file size of more than 64 Kbytes. [NDM-2090]The Wireless ISP connection can now link correctly to a third-party Wi-Fi network with an active
backhaul
support bit. [SYS-479]The Wireless ISP tile for 5 GHz connection on the Dashboard menu now links to the proper path, Wireless ISP > WISP 5GHz. [NWI-872]
KeeneticOS 3.7.2
20/01/2022
New
A new configuration option for improved compatibility with legacy Wi-Fi clients: Control the TKIP countermeasures
hold-down
timer. If the Wi‑Fi Access Point with WPA-PSK + WPA2-PSK protection mode detects twoMIC errors in RX
failures within 60 seconds, it blocks all the wireless TKIP clients on that interface for the hold-down timer. Use this command to disable or tune this behaviour. [SYS-434]interface {name} encryption tkip hold-down {hold-down}
— set thehold-down
timer in seconds (from 0 to 60). The default value is 60 sec.
Improved
Fixed
Fixed a sporadically occurring situation when data transmitted from the wireless interface of Mesh Wi‑Fi System Controller to an Extender, for instance, DCHP protocol, is blocked after reconfiguring the network segment. [SYS-436]
The LED power shutdown control now operates correctly with Keenetic devices having a single-LED indicator. [SYS-422]
Fixed an error in accessing the device's Web Interface after a few days of operation, causing the following messages in the System log. [NDM-2046]
ndm: Http::Nginx: there are errors in config, reconfigure.
ndm: Http::Manager: unable to update configuration, retry.
The IPv6 section of the System dashboard menu now displays only the default IPv6 gateway for the corresponding interface. [NWI-823]
Fixed the Fast Transition (802.11r) roaming selector behaviour in the Roaming for wireless devices section. [NWI-816]
KeeneticOS 3.7.1
10/12/2021
Improved
Enhanced Wi‑Fi Network protection: WPA2 Enterprise exchange with a RADIUS server now has Network name (SSID) in the
Called-Station-Id
message —'50-FF-20-AA-BB-CC:Keenetic-5555'
. [SYS-9]
Fixed
Corrected seamless Wi-Fi roaming operation: The forwarding of the LLC frames of the Inter-Access Point Protocol daemon now operates accurately via a backhaul link of the Wi-Fi system. [SYS-427]
KeeneticOS 3.7.0
28/11/2021
New
Improved
Implemented
/storage
partition formatting on factory reset, providing secure clearance of the private user's information or installed OPKG image. [NDM-1943]There are no changes for Keenetic Voyager Pro (KN-3510).
Fixed
The Wi‑Fi spectrum analyzer now operates when the Mesh Wi‑Fi System backhaul connection is disabled. [SYS-413]
Fixed the inability to set up a static DNS server address with the custom port setting in the Web Interface, for example —
1.1.1.1:5353
. [NWI-766]Fixed the forced disconnect of live Wi‑Fi clients when removing them from the Whitelist of the Wireless ACL. [SYS-400]
Fixed the false advertisement of 802.11k capabilities in Wi‑Fi network beacons. [SYS-414]
KeeneticOS 3.7 Beta 8
21/11/2021
Improved
Fixed
Fixed the issue of Wi‑Fi clients being unable to connect to a Wi‑Fi network with a hidden network name (SSID). [SYS-411]
Wi‑Fi system dynamic Fast Transition (802.11r) key exchange now operates appropriately when an Extender has the IP address changed over time via DHCP. [SYS-354]
KeeneticOS 3.7 Beta 7
17/11/2021
New
Implemented Wi‑Fi Spectrum Analyzer. The dedicated Spectrum Analyzer radio continuously scans all 5 GHz Wi‑Fi channels and visualizes the level of interference from neighbouring networks to help channel selection and planning. [SYS-297, SYS-393, NDM-1908, NDM-1858, NWI-590, NWI-708]
Improved
Removed an error message that occurred if an IP address was configured instead of a URL (Uniform Resource Locator) for a DoH (DNS over HTTP) server:
. [NDM-1938]Enabled centralized Wi‑Fi
country code
configuration from Wi‑Fi system Controller, and blocked this setting on Extenders. [NDM-1921, NWI-733]Improved operability of the Wi‑Fi connection in a noisy environment. [SYS-398]
Redesigned the display of active channels, and the colour legend of Wi‑Fi Channel utilization in the Wi‑Fi spectrum analyzer. [NWI-734]
Closing of Traffic monitor additional tabs is now allowed in mobile browsers. [NWI-666]
Added links to the Internet connections settings from the dashboard Internet tile, providing a fast way to edit connection(s). [NWI-682]
The PSK (PreShared Key) length is extended to 96 characters for IPsec and L2TP/IPSec VPN servers. [NDM-1780]
Implemented brute-force protection for remote access to the device via the KeenDNS domain name in the Cloud access mode. [NDM-1804]
The KeeneticOS update process is optimized to run in the background to minimize system downtime. Keenetic has dual flash memory with active and backup KeeneticOS images to ensure fail-free automatic upgrades. When a new version of the operating system is released, the device will download, store and check the integrity of the software image in the backup partition first, without interrupting the main operation. Then the Keenetic device reboots, running the updated KeeneticOS version. Internet access will be briefly interrupted only during the device reboot. [NDM-1861]
The hostname value is added to the Syslog message's payload when sending records to a server to simplify log analysis from multiple Keenetic devices. [NDM-1872]
Fixed
Fixed the occasional false "4 GBytes" bursts of apparent traffic in the Traffic monitor. [SYS-396]
The Static IP address assigned to a registered device now works more reliably. [NDM-1893]
Disabled validation of the DoT (DNS over TLS) / DoH (DNS over HTTPS) certificates until the system time of the KeeneticOS is synchronized. [NDM-1910]
Fixed the incorrect connection type in the More information section for Registered devices currently offline. [NDW-664]
The operation of the Wireguard VPN causes
no buffer space available
error message in the System log. [NDM-1913]
Restored the operation of simultaneous Wi‑Fi roaming zone and Wi‑Fi band restrictions applied to the device. The settings now propagate correctly to newly acquired Mesh Wi‑Fi System extenders as well. [NDM-1869, NDM-1875]
Fixed Network Time Protocol (NTP) server response validation under certain conditions. [NDM-1880]
Increased the server address length to 256 characters for PPTP and L2TP connections. [NDM-1907]
The Traffic monitor statistics now display correct information after changing settings on the WAN interface. [SYS-389]
KeeneticOS 3.7 Beta 3
30/09/2021
New
Added a user-defined caption to the Web Interface header and a browser tab providing improved navigation between multiple Keenetic devices. [NDM-1764, NWI-424, NWI-428, NWI-429, NWI-555, NWI-556, NWI-558]
Improved
Updated Wi‑Fi wireless driver to new version
7.5.0.0
. [SYS-373]Improved security: After changing user credentials, KeeneticOS cleans up active management sessions via the Web Interface and the Keenetic mobile application. [NDM-1860]
Fixed
Disabled requests from the Extenders to the Mesh Wi‑Fi Controller DNS proxy in additional segments. The Extenders now use Home segment only for system DNS requests. [NDM-976]
The availability checking for the SkyDNS® service now operates correctly when no additional DNS servers are configured. [NDM-1761]
The IKEv2 VPN tunnel now operates properly as a primary Internet connection along with the logic of automatic IKEv2 tunnel source selection. [NDM-1855]
KeeneticOS 3.7 Beta 2
This is the initial shipping release for Keenetic Voyager Pro (KN-3510).
