KeeneticOS component description
KeeneticOS supports the following components:
The information is for version 4.3.1
Languages
English, Dansk, Suomi, Français, Deutsch, Italiano, Polski, Português, Русский, Español, Svenska, Türkçe, Українська
A maximum of three web interface languages can be selected in the system. English is a mandatory component.
Basic components
System operating mode
Access point/Extender mode
For creating a new Wi-Fi network or to increase the coverage of an existing one
Adapter mode
For connection of non-Wi-Fi enabled devices to a wireless network
Repeater/Extender mode
For expanding the wireless network of another Keenetic
Internet safety
SkyDNS®
Safe Internet browsing with SkyDNS®
NextDNS
Cloud-based content filtering and ad blocking
Network functions
PPPoE client
Allows to establish PPPoE connections from this device
PPTP client
Allows to establish PPTP connections from this device
L2TP client
Allows to establish L2TP connections from this device
OpenConnect VPN client
Allows to establish OpenConnect connections from this device
SSTP VPN client
Allows to establish SSTP connections from this device
802.1X client
Provides login/password-based authentication support over Ethernet networks.
KABiNET ISP authorizer
This is the replacement for PC-based utility used by subscribers of the KABiNET ISP
PPTP VPN server
Allows to connect to home network devices using PPTP
SSTP VPN server
Allows to connect to home network devices using SSTP
L2TP/IPsec VPN server
Allows to connect to home network devices using L2TP/IPsec PSK
Site-to-site IPsec VPN and L2TP/IPsec VPN client
Allows to establish secure IP connections over the Internet
OpenVPN client and server
Allows to create OpenVPN tunnels
NetFlow Monitor
Gathers information about network traffic forwarded to the Internet and exports flow records to a NetFlow collector
Application-layer gateway (ALG) for FTP
Provides customized NAT traversal filters to support address and port translation for FTP protocol
Application-layer gateway (ALG) for PPTP/GRE
Provides customized NAT traversal filters to support address and port translation for PPTP/GRE protocols
Application-layer gateway (ALG) for RTSP
Provides customized NAT traversal filters to support address and port translation for RTSP protocol
Application-layer gateway (ALG) for SIP
Provides customized NAT traversal filters to support address and port translation for SIP protocol
Application-layer gateway (ALG) for H.323
Provides customized NAT traversal filters to support address and port translation for H.323 protocol
Application-layer gateway (ALG) for ESP
Provides customized NAT traversal filters to support address translation for the ESP protocol
IPv6
Provides IPv6 protocol support and related services
EoIP VPN tunnelling
Allows to create Ethernet over IP tunnels
GRE VPN tunnelling
Allows to create GRE tunnels
IP-IP VPN tunnelling
Allows to create IP-over-IP tunnels
WireGuard VPN
Allows to create WireGuard tunnels
IKEv1/IPsec and IKEv2/IPsec VPN clients
Allows to establish IKEv1/IKEv2 client connections from this device
Proxy client
Allows the establishment of connections via SOCKS/HTTP proxies from this device
ZeroTier client
A Smart Ethernet Switch for Earth: Create flat virtual Ethernet networks of almost unlimited size
OpenConnect VPN server
Allows to connect to home network devices using OpenConnect
IKEv1/IPsec and IKEv2/IPsec VPN servers
Allows to connect to home network devices using IKEv1 and IKEv2
Utilities and services
Service for mobile application
Provides remote management of your Keenetic device via the mobile app for Android and iOS
Cloud services agent and KeenDNS
The cloud agent provides services for devices to connect to the remote monitoring and management system (RMM) and operate the domain name KeenDNS service
Internet connection status monitoring (Ping Check)
Performs ICMP-, TCP-, TLS- and URI-based tests to verify the Internet connection status. Test results may be used to switch between primary and backup connections
Traffic classification engine
Provides detailed insights into network traffic with application and user-level visibility
Traffic shaper
Provides basic network bandwidth limitation functionality
UDP-to-HTTP proxy (udpxy)
Allows home network devices that do not support multicast traffic to watch IPTV channels
Dynamic DNS (DDNS) client
Keeps track of dynamic public IP-address on this appliance and maps it to a static domain name when changed
SNMP server
Allows to remotely gather statistics from this device
Captive portal
Application for creating a public Wi-Fi zone with SMS authentication
Packet capture
Allows to capture network traffic on router interfaces
DNS-over-TLS proxy
Provides domain names resolution via secure DNS-over-TLS protocol
DNS-over-HTTPS proxy
Provides domain names resolution via secure DNS-over-HTTPS protocol
mDNS service
Allows this device to handle and relay Multicast DNS and DNS-SD messages
OPKG packages
Open Package support
Lightweight package management system based upon OPKG
Kernel modules for file system support
Modules: FUSE, CIFS, NFS, UDF, ISO9660
Kernel modules for USB Video support
Modules: USB UVC
Kernel modules for USB Audio support
Modules: USB Audio, USB HID
Kernel modules for Netfilter
ARP Tables, Ethernet Bridge Tables, IP Tables, IP set
Kernel modules of the Traffic Control support
Schedulers: SCH_HFSC, SCH_INGRESS, SCH_CODEL, SCH_DSMARK, SCH_HTB, SCH_GRED, SCH_PRIO, SCH_RED, SCH_TBF, SCH_SFQ, SCH_TEQL
Classifiers: CLS_ACT, CLS_FLOW, CLS_FW, CLS_ROUTE4, CLS_TCINDEX, CLS_U32, CLS_BASIC
Actions: ACT_MIRRED, ACT_SKBEDIT, ACT_POLICE, ACT_IPT
Ematches: EMATCH_U32, EMATCH_CMP, EMATCH_NBYTE, EMATCH_META, EMATCH_TEXT
Kernel modules for USB over IP support
A solution for sharing USB devices over TCP/IP network
Kernel modules for USB DVB tuners support
Due to the different hardware configurations of Keenetic routers, we do not guarantee that all components and specific combinations of components available for a particular model can be installed at the same time. In addition, some operating system components are mutually exclusive and cannot work simultaneously.
You can get the recommended set of components by installing the KeeneticOS firmware for your device from the Download Center.
