Characteristics of supplied removable LTE antennas
Keenetic Hero 4G (KN-2310) comes with two removable omnidirectional cellular antennas.
SMA female connectors are used on the housing; the antennas are equipped with an SMA male connector.
The physical dimensions of the complete antennas are shown in the figure (in mm
Characteristics of the LTE antennas supplied with the package:
Frequency | 824 MHz ~ 960 MHz 1.71 GHz ~ 2.17 GHz 2.3 GHz ~ 2.69 GHz |
Impedance | 50Ω |
Standing Wave Ratio (SWR) | ≤3.5 Max. |
Antenna Gain | 824 - 960 MHz: 2 dBi 1710 - 2170 MHz: 3 dBi 2300 - 2690 MHz: 4 dBi |
Polarization | Linear |
Return Loss | -5 dB Max |
Cable Type | RG-178 |
Connector Type | SMA (Male) |
Operating Temperature | -40 ~ 65 ℃ |
You can use external directional antennas equipped with SMA male connectors (sold separately) if necessary. For more information, see Connecting outdoor directional antennas to Hero 4G(+) and Runner 4G.
