Method 1
Method 2
On the Extender, push the
In the same way, push the
button on the Main Router.
If you use a dual-band Keenetic model Buddy 5S (KN-3410) as an Extender, push the Wi-Fi button twice to connect to a 5 GHz wireless network. In the same way, push the button twice on the Main Router. If you push the Wi-Fi Control button once, you'll be connected to a 2.4 GHz Wi-Fi network.
