Resetting the system settings and admin password
Sometimes, you may need to restore your Keenetic to factory settings, i.e., reset the user settings to factory defaults. For example, if you want to reconfigure your router (delete all user settings) or have lost/forgotten your password to access the web interface.
A factory reset will erase all user settings.
After resetting, you will need to configure the router to connect to the Internet from scratch. Before resetting, make sure that you have all the information you need to configure the connection. If you don't know what settings to connect to the Internet, contact your ISP for that information.
Regardless of the current operating mode, it will go into Router mode after resetting the device to factory defaults. This only applies to models without a hardware mode switch on the case.
We recommend you temporarily disconnect all network cables from the Keenetic router when resetting.
Before performing a reset, save the configuration file (startup-config file) according to the instruction Saving the startup-config configuration file.
You can restore the factory settings in the following ways:
  1. Reset Button.
    This way of restoring the factory settings can be used when you cannot connect to the router's web interface (for example, if you cannot open a web interface page or have forgotten your password).
    The device has the Reset button on it. You can find it on the same side of the Keenetic where the rest of the ports are placed (the button's location depends on the model).
    On Buddy series Wi-Fi range extenders, you can reset the settings using the Wi-Fi Control button. Press and hold the wifi-button__1_.png button until its indicator light flashes rapidly. Release the button and wait for the repeater to reboot. The device will automatically reboot and restore factory settings.
  2. Web Interface.
    Go to the General System Settings page. Press the Reset all settings button to delete all user settings in the System Reboot section.
    In the Deleting Custom Settings window that appears, enter the word RESET (in capital letters) in the Confirm settings reset field and click Delete settings button.
    After that, the router will reboot with the default (factory) settings.
