Keenetic 4G (KN-1213-01-EAEU) Help Center
Authentication
Site addition
Routers importing
Site detail page
Dashboard
Nodes
Clients
Information
Telegram notifications
Site and node statuses
Status
Description
Colour
Online
Green
Offline
Red
Loading
Grey
Grey
Extender mode not supported
Grey
Pending activation
Blue
Unknown network error
Please contact our Support.
Yellow
Unknown response error
Yellow
Access denied
Yellow
KeenDNS not found
Yellow
SSL connection failed
Yellow
Timeout error
Yellow
Yellow
Cloud component not installed
Yellow
Temporarily unavailable
Yellow
Connection failure
Yellow
Reboot
Purple
OS update
Purple
KeeneticOS update for nodes
KeeneticOS update for sites
Node reboot
Site reboot
