Method 1
Method 2
    If you use a dual-band Keenetic model Challenger SE (KN-3911) as an Extender, push the Wi-Fi button twice to connect to a 5 GHz wireless network. In the same way, push the button twice on the Main Router. If you push the Wi-Fi Control button once, you'll be connected to a 2.4 GHz Wi-Fi network, but when Extender captured in a Mesh Wi-Fi System, the wireless connection between routers will only work in the 5 GHz band (currently a limitation of the Wi-Fi System design).
